Little bit of background:
I have checked for runout at the rear/front of the crank, and there is none. Maybe .001", but probably not even that much. After the wreck, I dropped the engine back in (after replacing all broken parts) and hoped for the best. Probably not the smartest thing to do, but it's all I could afford at the time. I have put probably around 100-150 miles on it since, and this is the first time it has been out since then (April). No oil pressure issues. Nice and steady at all RPM ranges. Running a Melling HV oil pump. Could that be masking an oil pressure issue? This is my first engine. Could the bearing wear be caused by improper tolerance? Too tight? Looks like heat marks. But, I'm no expert. Thanks. |
Possibly something bent or out of balance.
Bearing Problem ID. >> http://www.engineparts.com/publications/CL77-3-402.pdf |
Is it worth even trying to fix this? Pretty bummed right now, really don't know what to do. I spent literally over a year building this and am having a tough time with this. Very meticulously researching and putting it together, measuring, re-measuring..you get the idea.
oil
It's so hard to tell by pictures.
I think what you are seeing on the mains is the factory coating that will dis-color the bearings. I have some brand new in the box that look exactly like that. Post some pictures of the mains on the crank. Back to the accident, what happened and what parts of the engine were hit in the accident. Is this a internal or external balance crank??? Keith |
The actual engine was not hit during the accident. It was a frontal collision with a telephone pole that hit right between the passenger side a-arm and motor mount. Everything up front (electric water pump, alternator, pulleys, balancer) were damaged. The other damage occurred at the back of the block. When it hit, it split the bellhousing (scatter plate) from the block at the two upper most mounts, causing the block to 'shard' around the two upper bolt-holes. It did not crack through the block. When the car hit, the engine crossmember came upwards, forcing its way into the oil pan and I believe is the cause of why my balancer sheared off. It cracked the balancer hub and sheared off the keyway into two pieces. There was a crank throw imprint in the bottom of the oil pan. I cannot find any damage to the counterweights, but the pan had a windage tray and it was eaten alive. The metal mesh was all tangled inside of (I think) the number 3 rod and bolt. There was a slight nick on one of the rod bolts on #3, but it wasn't deformed to the point I couldn't get a socket around it. The transmission was a Super T-10, but the only thing hurt there was the case. The mainshaft did not bend and I actually replaced the tail case and put it back in. Driveshaft came out and put a couple dents in it, and one of the axle tubes in my rear came out (bent axle, come to find out later). EDIT: I will be re-checking the main bearing clearances tonight and I will get some pictures of the crank and the journals. If it were an oil starvation issue, what would the crank journals look like? They still look polished and clean like they did when I put it in the first time. Edit 2: Here are some pics of the lower bearing halves. I don't remember which ones went where, but I think they're all there. ![]() ![]() ![]() ![]()
engine
Keith |
Wouldn't there be an excessive amount of runout though? I measured for it at the rear, front, and the middle three main journals but there was none. Also, wouldn't the main bearings looked chewed up a bit more? I did run it for 100 miles or so.
crank
Not if the snout is bent.
I had a LG 327 crank that was bent on the snout .020" and all the mains were less then .0005" for run-out. Also in light of the accident description, check the flange at the rear of the crank for run-out also. Keith |
Thanks Keith. |
crank
I would probably spin it in a crank grinder just to see if anything shows up, and have it wet magged for cracks.
It sounds like the crank is ok, but with all the damage you described i would be looking real close at it. Did you use the same T-10 that was in the accident??? Keith |
I originally used the same Super T-10, just replacing the tailcase and welding on the broken mounting tab, inspecting the gears, etc. It was toast, second gear was not available when up shifting, and third was toast after a while. I sold it and bought a Magnesium cased circle track tranny (G-Force case with stock gears). Last edited by mrdreex; 10-23-2009 at 08:13 AM. |
| Small block chevy main bearing issue (assembly) | JoshF | Engine | 11 | 06-20-2008 06:22 PM |
| Parts I.D. Help Bellhousing, clutch/pp, Throw out bearing. | isahar | Transmission - Rearend | 1 | 10-30-2007 12:50 AM |
| Problem setting up guts of ten bolt | rwruther | Transmission - Rearend | 18 | 08-30-2007 10:07 PM |
| "tapered" rear axel bearing question | powerrodsmike | Transmission - Rearend | 3 | 08-10-2007 04:47 PM |
| tiny little fish-scale-like flakes of bearing on bearing/journal | bullheimer | Engine | 2 | 04-16-2004 01:12 PM |
