Bearing/main cap organizer - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2013, 07:43 PM
Last journal entry: getting started
Does anyone have a good Bearing/main cap organizer, whether it is homemade or store bought? I want to put the caps back in the correct location and want to have set aside for a while..
Old 04-26-2013, 12:59 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Just mark them with a center punch front to rear, or buy a letter/number punch set from ACE Hardware.
Semper Fi
Old 04-26-2013, 06:27 AM
Another solution is to buy an electric engraver from Lowes. Number the main bearing caps as you remove them. You can also number the rods and the rod bearing caps.
Old 04-26-2013, 07:03 AM
Thanks
I wasn't sure if it was soft enough to punch or engrave without ruining something. I knew using a paint stick would come off during cleaning.
Old 04-26-2013, 08:08 AM
Banned
engraving is the most common approach to keeping them in order. The only problem with that is hat if you want to keep bearing shells in order that approach is useless. For the shells as a quick temporary fix I use an egg carton- you can write on it and they keep the the bearings from moving around.
I used to just put them on a labeled sheet of paper but invariably a few of them would move around.
Old 04-26-2013, 08:22 AM
Ditto the engraver. Marking and center punches displace much more metal.
For bearings, as you disassemble, wash each one "by hand" with brake clean and a soft cloth. Use a Sharpie (permanent marker) and write the number and position on the back.
FWIW
Jim
Old 04-26-2013, 10:58 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Originally Posted by Mr. P-Body View Post
Ditto the engraver. Marking and center punches displace much more metal. FWIW. Jim
Displaces too much metal?? We're talking a small dimple, but as you said, FWIW.
Semper Fi
GM 4CYL Main bearing cap installed wrong, what do you think? tru2037 Engine 6 06-20-2012 07:53 PM
5.7 Vortec Rear Main Cap Plug/Ball Bearing? PalmerXJ Engine 1 07-09-2008 06:03 AM
bearing dust cap..can't find one rambo Suspension - Brakes - Steering 2 05-28-2008 12:58 PM
Rear main bearing cap question...SBC bennett Engine 1 06-20-2004 02:24 PM
What main cap girdle would you recommend for a chev 400 with a 2 bolt main stonedchihuahua Engine 19 01-05-2003 06:31 AM
