Bearing No. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2002, 02:53 AM
Post Bearing No.
Does anyone know the bearing no. used in a 6-71
blower frount & rear bearing plates; I talked
to B.D.S., But they were un-willing to give up
thay information.
Thanx
[ December 13, 2002: Message edited by: jblair ]</p>
Old 12-06-2002, 01:05 PM
SAE Member; ASE Master Cert
Post
Are you using the stock GM bearing plates?? If so, call your local Detroit Diesel engine parts outlet. They can fix you up with the correct bearings. Since the 6-71 has been around for many years, it is very possible that there have been changes in the plates and/or bearings. Best bet is to take the plates and old bearings in with you to the store.
Old 12-06-2002, 02:16 PM
roys63's Avatar
Post
Try Kuhl Superchargers @ www.kuhlsuperchargers.com they may give you the info you are looking for, or sell you the right changeover bearings and front seals.
