Originally Posted by GMC boogie
[IMG]I did have the block align bored at a very reputable machine shop that has been in business doing primarily circle track engines for a long time. Most of the local area machine shops use him for their align bore work.
It is a '76 959 casting block. The crank is a 4.25 Scat cast steel. Clevite bearings. Only plasigauged under main caps in one spot.
I realize plasigauge is not the best method. I was really wanting .0025-.0027 as this will be street/strip car.
The more professional way would be to line hone not line bore when machining for a performance build. I line bore when putting new caps on and always finish with a line hone. I have always said Line honing always brings out the imperfections of line boring. I have seen this to many times!!!
Like Tom said there are signs of taper some where of even a crank that is not straight.
