bearing tangs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2004, 06:58 AM
Zartan's Avatar
bearing tangs
do the bearing tangs for the mains, and the rods, go on the same side or the opposite sides? in other words, both on inside block side or one on inside, other to outside?
Old 02-11-2004, 07:53 AM
woodz428's Avatar
Troll Hunter
Arrow
I won't make a sweeping comment, because I've assembled hundreds of different type engines. Not knowing what engine it is I would say that MOST likely the tangs go toward the outside on a V8.
Old 02-11-2004, 08:13 AM
Zartan's Avatar
sorry...it's a gm goodwrench 350..
one guy told me they go on the same side(inside) and another said opposites. since the tang groove for the block bearing is fixed, it sits to the insidei'm wondering if the cap bearing tang is same side or opposite, and does it matter and if so, why?
Old 02-11-2004, 09:23 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
They will just fit one way.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 02-11-2004, 09:42 AM
Zartan's Avatar
i know the tang grooves on the bearings fit into the grooves on the block and the cap. the question is, when i put the cap on, am i putting the cap w/ the tang side to the same side as the tang on the bearing in the block, or opposite?
Old 02-11-2004, 10:10 AM
troy-curt's Avatar
The cap is marked with a <----<<< pointing to the front of the engine.
Troy__________________
Old 02-11-2004, 02:07 PM
BOBCRMAN@aol.com's Avatar
USUALLY! on a small block chevy the main bearing and rod bearing tangs go together on the same side. There are some exceptions that I have run across in the last 40 years. If the block has had main cap work or rod resize work sometimes the tangs will be different depending on the rebuilder or what came out close enuff to recut to standard. I have also seen stock GM blocks with main caps on backwards from the factory, so it does happen.
Old 02-11-2004, 02:35 PM
Zartan's Avatar
thx.
i'm really curious as to why this is the case...why it matters?
Old 02-11-2004, 05:21 PM
troy-curt's Avatar
The caps are put on at the factory or the machine shop, then they are line bored, from then on they must be assembled that way every time they are taken apart.
The first thing you should do when taking the engine apart, is to mark the rod and main caps if they are not already marked. They HAVE to go back on where they come off, or you will have to line bore it again.
All the chevrolet engines I have worked on the tangs go on the same side.
Troy
Old 02-11-2004, 05:46 PM
NorthStar's Avatar
On the rods the tangs should be on the same side when bolting cap & rod together.
But I would be more concerned that the chamfered side of rod is facing radius on crankshaft. If you put that together backwards there will be a big problem.
