bearing or tie rod
i have a 94 grand prix ,thought i had a bearing bad but when i jacked it up bearing tight inner tie rod bad ,,,can this give the same noise as a wheel bearing ,,,makes the noise when i turn left , tie rod on right bad..what you think guys???thanks
found bad bearing replaced but....
what about the inner tierod never tried this,i have replaced whole rack on ford sho before...what is the best to do replace rack or just inner, just wondering ......
Tie rod ends will not make a bearing type noise. If it is more of a clicking than a whine it is probably an axle.
Artificial Intelligence is no match for Natural Stupidity Chet |
Agreed with Chet, Clicking is usually the axle / cv joint.
I have seen the brakes / wheel bearing make the bad bearing sound when turning the wheel also.JMO Fix the tie-rod as stated then go from there.IMHO Cole |
| Rod length discussion, split from previous thread | seriousracer | Engine | 11 | 06-29-2007 12:27 PM |
| 5.7" vs. 6" | savman1 | Engine | 30 | 01-20-2006 09:17 PM |
| 327 in 88 Truck | pete379 | Engine | 101 | 01-19-2006 09:03 PM |
| tie rod end stud too long? | guba_unus | Suspension - Brakes - Steering | 2 | 01-06-2005 08:08 AM |
| Tie rod ends (converted GM to rack) | Andym | Suspension - Brakes - Steering | 3 | 08-29-2003 03:38 PM |
