Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bearing Trouble
Thread: Bearing Trouble
Old 03-25-2011, 11:49 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Black w/chunks missing could have been caused by a lack of lubrication that caused the bearing surface to overheat and begin to weld itself to the crank journal. The lack of assembly lube might have played a part in this, as could a lack of pre lubing the engine by spinning the oil pump w/a drill prior to first start up.
The "record disc" feeling is likely caused by grit or metal shavings and particulates left from machining or insufficient cleaning.
