Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bearing Trouble
Thread: Bearing Trouble
Old 03-25-2011, 08:35 PM
Linez35 Linez35 is offline
Yes i do have alot to learn from every mistake is something you learn and i definetly learned from this. the reason for rebuilding was because a bearing went out and i cleaned it myself so this time im gona have a machine shop clean it. should you always prime the pump even with assembly lube?
