Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bearing wear
Thread: bearing wear
Old 02-24-2011, 12:08 PM
jeepers creepers jeepers creepers is offline
bearing wear
While tearing down oil pump today i've took off some cap to see main bearings conditions and this is what i've found:
[IMG=http://img141.imageshack.us/img141/4468/img0476d.jpg][/IMG]
Uploaded with ImageShack.us
engine had run for about 2 h, just for the set up, non road, i've cleaned doing my best all tunnels, holes everithing in the engine blowing with compressed air, and solvent, engine was perfect at the assembly, coated all bearings with specific lube, checked all the clearances , they were fine...
As you can see crank looks like perfect, but wear pattern on the bearings are telling something wrong, misalignement?
i'm so frustrated.
