Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bearing wear
Thread: bearing wear
Old 02-24-2011, 01:47 PM
jeepers creepers jeepers creepers is offline
Thank you for the quick and professional response as usual Bogie.
Can the "fine material" be the Moly grease used on the bolts?
i've seen a lot of this in the oil pan, i did an oil change already but the fine particles are probably heavy so they tend to stay.
i'm afraid to see rod bearings now, don't know what to do, i've a new set of bearings on the shelf but i think that once changed the story will start again so it's probably useless.
Any advice?
Thank you.
