bearings went out....
i have a chevy 468 /9:1 comp/flat top pistons
and the bearings went out i didn't run it much do you think it destroyed the cam?? there are not alot of metal shavings in the pan look at cam had it for 1 year min driving on it. some wear had roller rockers on it |
i used a mircrom on the cam they all are the same size!!
is they anything else i need to concider |
Are you talking about the rod or main bearings went out ?
Cole |
the main bearing ,the crank has .1000 lip on it, a machinist can grind
it right? |
I have went in and did just the bottom end without any problems. You will need to take the crank to a machine shop to make to call on it. Just go ahead and do rod's and mains and a new oil-pump while you are in there thats what i would do if everything checks out ok. JMO Someone else might say different, But i have done this more then once without any issues.
How many miles do you think the engine has on it ? Cole |
ok thxs for the reply
ya thats would make sence,the lobes on the cam really
arent that bad with measurement |
ok that true
| 4.3l V6 rod bearings | Gearjammers | Engine | 12 | 02-16-2012 03:34 PM |
| 383 bearings | bracketracer | Engine | 7 | 08-30-2010 01:13 PM |
| Are these the correct bearings?? (main bearings) | LandonL | Engine | 3 | 08-29-2010 07:46 AM |
| Oil and Bearings a.k.a. Hydrodynamic Bearings - FWIW | Stroke | Engine | 1 | 03-25-2008 08:55 AM |
| King Bearings good? Looking for good bearings | Warrant | Engine | 4 | 06-11-2006 06:50 PM |
