Beating a dead horse, Timing help please - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 07-13-2008, 10:00 AM
scapegoat's Avatar
At what point did I have an "attitude"? I barely reacted to the negetive posts. I guess the balancer and timing questions should have been split up in different threads. Honestly though where did I come off with an attitude?
  #47 (permalink)
Old 07-13-2008, 10:10 AM
scapegoat's Avatar
At post #28 is where the attitude was started by another member not me. Check it out for yourself,seriously. But anyway I ordered a new balancer and pointer so all will be well in a few days.
  #48 (permalink)
Old 07-13-2008, 10:23 AM
malc's Avatar
Living At The Speed Of Life
Originally Posted by scapegoat
My carb does not have a timed vacuum port so I am not using the vacuum advance. Was I suppose to plug the port on the advance canister? I just left the canister open but I pluged all other vacuum ports.
For me it started at this post, you stated your carb hasīnt got vacuum ports when it damn well has, this you ignored as well and went back to the balancer.
First of all check the stuff you have then if itīs wrong replace it.
There is more than enough info in this thread to do what you have to do.
Find top dead center and make a pointer out of an old coat hanger if you have to to get started.
Your next post should be thank you guys I got īer dun.
  #49 (permalink)
Old 07-13-2008, 10:52 AM
Throw your timing light to the earth. If the car starts without problems take it for a ride. If it drives OK and doesn't make the death rattle find yourself a big concrete light pole base and drive up to it. Throw an old tire or other item between your vehicle and the concrete. Start it up, put it in drive until your vehicle stops. Give it some goose. Does it hesitate, does it ping, or does it burn the tires? Adjust it until you only get the roast going on and the vehicle starts without issue. Tighten the distributor and test drive, pay attention to part throttle load at cruise and how the engine 'feels'. If at this point you feel you need to adjust , do so until it's right for you. Good enough, drive on down the road. No need for anyone to get their panties in a bunch. Done this a million times without fail when no timing instruments were available. Later checking never warranted change.
  #50 (permalink)
Old 07-13-2008, 06:01 PM
garyroushkolb's Avatar
Last wiki edit: How to find an electrical drain Last photo:
I've never tried pushing a light pole like "Stroke", but it's saver than hammering it on a back road that we usually did. What he say's is 100% correct, advance it till it runs good and still starts ok. Gee-that's what we said before.
  #51 (permalink)
Old 07-13-2008, 06:09 PM
Guys, Guys, Guys,
What the hell is going on here?
I just went back and scan read most all the posts.
What is the big deal if someone doesn't understand something or doesn't know how his carb works.
Why do some people get so damn upset about it?
Why do people read something obnoxious into some post's verbage?
Aren't we HERE to help people learn and help people fix their problems?
What the hell is happening to this site?
  #52 (permalink)
Old 07-14-2008, 07:07 AM
scapegoat's Avatar
I know my carb has vacuum ports, I just said that they are full manifold vacuum not timed. And the picture of the baseplate you posted is not totally like mine. Mine has the two in the front and one big one in the back. I know the one in the back is full vacuum and at least one of the two in the front is full as well. I havent checked the second one in the front yet for full or timed vacuum.
Im just waiting on a new balancer. Should be here in two days.
I was driving the truck around for about a week before the balancer issue. It ran okay and had a ton of power. It would annihilate the tires at 30mph and continue spinning all th way through drive. But at that point it was not timed with a light. I just set it until it sounded and performed okay. It got a little hot though. Thats why I was thinking I should time it. Incase its running hot because of it being out of time.
  #53 (permalink)
Old 07-14-2008, 07:11 AM
scapegoat's Avatar
But seriously, that was the post that pissed you off? What did I say wrong?
  #54 (permalink)
Old 07-14-2008, 08:05 AM
scapegoat's Avatar
Originally Posted by ScoTFrenzel
Guys, Guys, Guys,
Well said.
I guess im stupid for asking questions about timing a sbc. Even though I personaly built 100% of my project. Alot of people can't say that!
  #55 (permalink)
Old 07-14-2008, 08:30 AM
wretched ratchet's Avatar
one full turn after it squeeks
Originally Posted by cool rockin daddy
Amazing. Malc gives you excellent advice and a great article. You then flame him for questioning your dedidcation and your level of knowledge about YOUR OWN parts when you admit you didn't even read the instructions for your parts! Then you come up with the tired "this is an open forum and I am just trying to learn" B.S.!!! Now in your infinite wisdom you inform us all that you can't time your engine due to mismatched balancer and timing tab! Guess your original post wasn't needed, was it? Fix your mismatched parts, read the article that was suggested, and time your engine. Simple, no?
Another example of the new age rodder. Asks questions, doesn't understand the answers even though he says he is reading up on the subject, gets mad at somebody kind enough to post a reply, then diagnoses the problem himself by doing what he should have done in the first place; GETTING HIS HEAD UNDER THE HOOD OF HIS VEHICLE AND INVESTIGATING! That's the definition of hot rodding in my opinion. Far too many people are moving away from that I fear.
WHAT HE SAID ! ! ! ! !
  #56 (permalink)
Old 07-14-2008, 08:50 AM
Frisco's Avatar
Glad To Be Here
One of the smaller ports in the front is the "timed" vacuum port.
You probably do not need this item based on what you've posted.
If you drove it for about a week before it got a "little" hot; the timing probably was not the reason the engine got hot.
I just want this thing timed so I can drive it to the exhaust shop to get some pipes hooked up. I will be driving open headers.
Your original question concerning the timing was answered several times, by different folks.
Your second (sort of) question about whether or not you had a timed vacuum port on your carb was answered and you eventually stated that indeed you did have three on your carb (this was after you stated that your carb did not have a vacuum port).
Your third question concerning the harmonic balancer was also answered several times, by different folks.
Now it seems like you want to have a pissin' contest with some of the folks that attempted to assist you.
Did you ever drive it to the exhaust shop to get your pipes hooked up?
Did you ever set your timing correctly?
I think this thread is ready to be either CLOSED or sent to the DUMP.
What ever happened to the link to "REPORT THIS THREAD"???
I know where the "REPORT BAD POST" link is.
  #57 (permalink)
Old 07-14-2008, 09:07 AM
scapegoat's Avatar
I did not say that I didn't have vacuum ports. You are putting words in my mouth. I said I didnt have a timed vacuum port. Where are you guys getting all this stuff I never posted?
  #58 (permalink)
Old 07-14-2008, 09:20 AM
Frisco's Avatar
Glad To Be Here
See my answer at post #27 or my revised comment above.
  #59 (permalink)
Old 07-14-2008, 09:21 AM
scapegoat's Avatar
I said I didnt have a "timed" vacuum originally. I never said anything about not having vacuum ports. Of corse I have vacuum ports.
  #60 (permalink)
Old 07-14-2008, 09:24 AM
scapegoat's Avatar
I don't want full vacuum for my vacuum advanced. I want timed don't I? It would probably run better with it hooked up either way it think.
running no vacuum advance oregon chevelle Engine 28 02-07-2007 07:17 PM
ignition timing (in relation to rpms) KNanthrup Engine 8 05-21-2006 04:16 PM
What's a good timing curve for a 4100lb car? Malibu73 Engine 3 03-04-2006 12:51 AM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 04:26 PM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
