Beating a dead horse, Timing help please - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 07-14-2008, 09:26 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Originally Posted by scapegoat
I don't want full vacuum for my vacuum advanced. I want timed don't I?
You should use full manifold vacuum for your advance. This will give you better fuel mileage, and performance.
  #62 (permalink)
Old 07-14-2008, 09:29 AM
scapegoat's Avatar
Seriously? I swore it was for timed. Will it make it more "crisp" in the pedal at cruising speeds?
  #63 (permalink)
Old 07-14-2008, 09:36 AM
My 2 cents worth
Wiki Edits: 3
Yes
When you "give it more throttle" the vacuum advance will drop off. This helps to keep it from pinging, and in return, lowers the "heat" in the engine.
  #64 (permalink)
Old 07-14-2008, 05:06 PM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
Oh my goodness... this started out as your standard run-of-the-mill basic timing troubleshooting... then UGH... all of this "old timers" versus "noobs" nonsense.
There always have been and always will be cranky people on this forum. That won't change.
And there will always be a search feature, a knowledge base, etc, but that doesn't mean people will use it wisely.
It's not about how old you are, or how much you know, it's about a passion for cars, engines, etc. etc.
Chill out everybody.
That's all, end of my rant.
On another note, good luck with your timing issue! get yourself a TDC checker tool (vented) and a cam degreeing wheel. Mark your balancer properly (mark the inner and outer rings so that you can check for slippage down the road). Time the engine for 36-38 degrees full advance, and go drive it. After you're done at the exhaust shop, then follow up and re-check the timing.
peace.
the blonde weasel
  #65 (permalink)
Old 07-14-2008, 06:56 PM
cool rockin daddy's Avatar
Again, the knowledge base. A fantastic article on why manifold vacuum is better than ported vacuum for most street driven engines. Do you know how to look something up in the knowledge base?
running no vacuum advance oregon chevelle Engine 28 02-07-2007 07:17 PM
ignition timing (in relation to rpms) KNanthrup Engine 8 05-21-2006 04:16 PM
What's a good timing curve for a 4100lb car? Malibu73 Engine 3 03-04-2006 12:51 AM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 04:26 PM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
