Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Beating a dead horse, Timing help please
  #48 (permalink)
Old 07-13-2008, 10:23 AM
malc's Avatar
malc malc is online now
Born To Be Mild
Originally Posted by scapegoat
My carb does not have a timed vacuum port so I am not using the vacuum advance. Was I suppose to plug the port on the advance canister? I just left the canister open but I pluged all other vacuum ports.
For me it started at this post, you stated your carb hasīnt got vacuum ports when it damn well has, this you ignored as well and went back to the balancer.
First of all check the stuff you have then if itīs wrong replace it.
There is more than enough info in this thread to do what you have to do.
Find top dead center and make a pointer out of an old coat hanger if you have to to get started.
Your next post should be thank you guys I got īer dun.
