Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bed liner removel
Old 03-19-2012, 04:51 AM
Irelands child's Avatar
Irelands child Irelands child is offline
These are a "pleasure" to remove. A pair of pliers to squeeze the two halves of the clips together that you will see if you lay on your back in the bed and look up at the underside of the rail is usually all you need. The ones nearest the cab is a b###h There are, if I recall (been a while) at least a half dozen of those snap in clips. A second person to help keep some tension on the rail will help too. Fair warning - there may also be glue or two sided tape on the underside as well if a stealership needed to do a quick and cheap repair. You may also break some of those clips - then your repair is that tape(glue) or a ~$110 each replacement
Irelands child
