Beefing up G-Body 1986 Cutlass Suspension - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-15-2010, 08:05 PM
ericnova72's Avatar
More for Less Racer
You might want to investigate the 8.8" Ford Fox Mustang rear swap, this is starting to get popular and supposedly is fairly easy to do, pretty much a bolt in with the right arms. The 8.8" is quite close in strength to a GM 12-bolt.
  #17 (permalink)
Old 01-15-2010, 10:36 PM
SSedan64's Avatar
I keep forgetting about the 8.8" swap Eric.
Here's lots of Info/links on that swap>> http://www.maliburacing.com/forum/vi...hp?f=4&t=72070
Todd
  #18 (permalink)
Old 01-16-2010, 10:43 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Awesome thanks for all the replies everyone!! I think for now I am gonna just box in the control arms and leave the 7.5" rear end in the car. I am sure down the road I am going to swap in a 9" or maybe even the 8.8" to handle a little bit more power reliably. I will post before and after pics of the control arms when I can get all the snow out of my way to unbolt them.
What thickness steel should I use?
  #19 (permalink)
Old 01-16-2010, 11:44 PM
SSedan64's Avatar
I've used these before>> http://cgi.ebay.com/ebaymotors/64-72...item3ca93c852c may find them for G-Body also. 14ga. or thicker steel.
  #20 (permalink)
Old 01-17-2010, 08:30 PM
Listen and Learn
Wiki Edits: 7
alright thx again ssedan!!
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Suspension for '71 Cutlass Monsoon Suspension - Brakes - Steering 0 02-26-2004 07:08 PM
C5 Vette suspension into a fox body Mustang Beau Suspension - Brakes - Steering 2 02-13-2003 07:39 PM
86 cutlass suspension 86cut Suspension - Brakes - Steering 0 07-21-2002 08:38 AM
Cutlass body parts scoutman33 Body - Exterior 1 01-27-2002 09:08 PM
