Been along time need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2013, 04:09 PM
Well let me first start off by saying I haven't built a motor in about 15 years or so. That being said I'm kinda rusty and all of your help would be greatly appreciated . First lets start with a bottom end question. I have a 350 block bored .030 and I was thinking of building a stroker. Pistons and rods have already been upgraded. If I buy a internally balanced crank can I use factory balancer and flex plate . Thanks again for any input.
Old 01-06-2013, 07:13 PM
vinniekq2's Avatar
the balancer/flywheel/flex plate will work internally balanced 366/383/388s the pistons have to be matched to the new stroke.If you bought 355 pistons then you can build a 355 only
Old 01-06-2013, 07:22 PM
Richiehd's Avatar
JS-70
Vinnie, can you build a 327 if you use 6 inch rods? (.030 over 331)
Old 01-06-2013, 07:39 PM
vinniekq2's Avatar
Of course you can use 6 inch rods in a 331. you need the correct pistons. Do you have a reason to upgrade to 6 inch rods?
Old 01-07-2013, 12:03 AM
Cars, Trucks, Boats
.. You would need about 5.835" - 5.850" custom rods to re-use 350 pistons with a 327 crank... depending on exact deck height of block and compression height of pistons...
.. Prolly cheaper to change to 327 pistons and use standard rods...
Old 01-07-2013, 12:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
First, welcome. Building an engine is much the same as riding a bike- you'll catch on quickly once you get into it.
To use 1.56" compression height (CH) 350 pistons (stock sbc 350 CH in other words) to build a 383 stroker, you'd have to use the stock sbc 400 rods that are 5.565" long. This isn't usually done; most all "kits" use a 5.7" rod, some also use a 6" rod, and these require pistons w/their own CH.
You can build an internally balanced 383 stroker, but it's usually more expensive. Of course the cost of a different balancer and flexplate/flywheel has to be considered as well. But in many cases they need to be replaced anyway, due to age/wear.
While the 383 stroker gets all the buzz nowadays, there's not a thing wrong w/building a 350 SBC for most applications.
More here.
Old 01-07-2013, 10:53 AM
Richiehd's Avatar
JS-70
Raceboat motor, more RPM
Old 01-07-2013, 10:56 AM
vinniekq2's Avatar
more RPM is a little vague? High RPM is expensive.Over 7,500 is very expensive.Boats are hard on engines
Sewing machine comparison-long time seamstress, 1st time upholsterer - Singers altheapdx Interior 8 09-05-2012 11:27 PM
converting transfer case np203 from part time back to full time blade12376 Transmission - Rearend 1 12-05-2011 07:53 PM
Interesting time test I did on fuel vs time used for my commute. MARTINSR Off-Topic 5 08-27-2010 10:37 AM
Long time knucklebuster first time forum user davo-usa Introduce Yourself 3 10-07-2009 08:44 PM
1st time caller, long time listener 56Cameo Introduce Yourself 1 07-19-2004 12:06 PM
