Been awhile, Pontiac motor question for ya - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2011, 03:41 PM
So I might be inheriting a 1974 Trans Am, completely original, owned by my uncle since it was new. He let it sit for a long time with hopes of fixing it with his son but due to his son having no interest in cars and my uncle going through a bad accident recently they might be sending it my way to see it get brought back to glory. I've got pretty much everything planned out for my build except deciding on the motor. I was thinking about rebuilding the 400 with a 461 stroker assembly, having Butler rework the factory 4X-7H heads, Edelbrock RPM intake, and camshaft selection is up in the air (maybe a custom grind). I'm thinking this motor in front of a TH400 with say a 3.42 gear would make a nice street/strip setup with a ton of usable torque. I don't have alot of experience with the Pontiac engines (aside from the old OHC's!) so your opinions would be appreciated. The main uses of the car would be weekend enjoyment, hitting the shows and trips to the local strip. I'd love to get the car into the low 12's on motor and I think this would be easily attainable while still being full weight and dressed up car.
Old 07-01-2011, 04:55 PM
Shaker455's Avatar
I think your on the right track with a stroker set up so go for it!
SD performance has a good off the shelf roller cam selection that will help you obtain your drag goals.
Old 07-01-2011, 05:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The cost for porting iron Pontiac heads only makes sense if the build is a restoration, IMO. The iron D-ports can be made to flow decent numbers, but stepping up to a set of aftermarket heads will be worth big power. I'd go as far as to say the 400 engine w/aftermarket heads will run right with a 461 w/stock iron heads. Put the AM heads on the stroker and forget about it! You'll want to buy stock in Goodyear.
Old 07-02-2011, 12:34 AM
Thanks for the advice, I was just reading up on some of the head discussions and thought I could reach my goals with the stock heads so that is why i mentioned them. If I can attain a goal and save some $$$ on the way, I'm ok with that. I was looking at the Edelbrock castings the other day and have been keeping my eye on them. I've been debating if it would be worth throwing a nice 700R4 in it or just keeping the TH400, maybe rebuilt with the lower 1st/2nd gear and run a slightly lower rear ratio. The car will see highway trips with about 70mph speeds so that is something I am considering right now too.
Old 07-02-2011, 03:23 AM
Why use a 700r4 when the 200-4R will bolt directly to the back of the Pontiac with out an adapter, and the trans can be built to handle anything you can throw at it(just look at the Turbo Buick guys) The 200-4R has better spread between the ratios, the 700 has a huge drop from first to second.
Old 07-06-2011, 01:55 AM
lemondana's Avatar
74 Trans Am
I'm not a Pontiac guy but I don't think the Edelbrock RPM intake will fit under the hood, at least if you have the Shaker type hood. I could be wrong though. Sounds like a fun car-good luck!
Old 07-06-2011, 02:59 AM
New Member
Old 08-15-2011, 07:51 PM
I have two Edelbrock Performer intakes on Pontiac engines under Firebird Formula hoods. The air cleaner hold-down nut has rubbed a hole through the yellow car's hood. The blue car's hood is almost rubbed through so I'm putting the stock cast iron manifold back on that one.
A friend has a high-rise single plane intake on a Trans Am. He couldn't/didn't want to deal with clearance issues so he bonded the scoop to the hood. Personally, I wouldn't do that but it worked for him.
There's not a lot of vertical clearance under a 2nd gen Firebird hood.
Old 08-15-2011, 08:12 PM
Rhansen's Avatar
Footbraker
Friend of a friend has a similar build but with the Edelbrock aluminum heads - made it deep into the 11's.
http://www.dragtimes.com/Pontiac-Fir...slip-5892.html
Old 08-17-2011, 04:06 AM
67TEMPtress's Avatar
Second that.
Old 08-17-2011, 09:58 AM
bigdog7373's Avatar
Of course it's fast
4 speed! Or 5 speed with overdrive for hwy. Auto is boringgggg.
A/C on pontiac motor kear69cat Hotrodding Basics 10 04-15-2011 05:50 AM
what can you tell me about the motor in my 40 pontiac Modern_twist Engine 4 07-18-2009 02:33 AM
Pontiac Motor Mounts solidaxel Engine 6 05-25-2007 08:09 PM
been awhile... question Slightly_Slanted6 Hotrodders' Lounge 0 12-22-2004 10:15 AM
Pontiac Motor Jessab Engine 5 01-06-2004 03:57 PM
