Before base coat, use of wax & Grease remover - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2009, 03:36 PM
I am getting ready to do a paint job using 2 colors, How long after I apply wax & grease remover can I apply PPG Base?.
Also can I use the wax & grease remover after I have removed tape from the first color, to get rid of any tape adheasive ?
Thanks !!
Old 03-12-2009, 03:58 PM
302 Z28's Avatar
IT depends on the ambient air temp as to how fast it will evaporate after wiping it off. The key is to wipe it on then with some clean paper towels wipe it dry. DO NOT just wet it down and leave it to evaporate, you will have problems. Wax and grease remover ( if it's PPG brand) will not remove the base if you do not rub it excessively.
Vince
Old 03-12-2009, 04:39 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Don't use the standard Bounty or home paper towels to wipe it down. Some towels have inks in them for printing and others will leave lint and a residue. They do make a paper towel that you can get in packs from your local jobber for using the wax and grease remover. As far as a time frame. I have shot base anywhere from 15 minutes to a half hour afterwards. Just make sure you tack off the area before you spray your base but after you use the W&G remover to get rid of any possible lint debris.
Old 03-12-2009, 06:53 PM
Here is a little "Basics of Basics" on surface cleaners ("wax and grease remover")
I wrote this a few years ago so the part numbers may have changed but the info for use is still the same.
Click the link.... http://autobodystore.com/ms8.shtml
Old 03-14-2009, 11:46 PM
Degreasing
I just wanted to ask why you would want to degrease before you apply your base coat? I'm not sure what you are painting but I have found through experience that using a degreaser right before painting always gave me some sort of problem (I use a brand called Tumbler). Usually as Martinsr says this is done before anything is sanded to begin with. Now again through experience I found it best to clear over base before you tape, using something like DBC 500 blending clear seems like the glue on the tape and fresh base coat collide, sometimes I would shoot a coat of 2021 depending on what I was doing, especially with flames as I wanted a good base. Anyways hope this saves you some time.
Old 03-15-2009, 08:12 AM
Thanks, I am spraying 2 colors and didn't want any (sticky) from the tape to be left behind. I thought I could use wax and grease remover to completely clean the surface after the removal of tape.
Thanks !!
Old 03-15-2009, 08:39 AM
WHOA there Rodder1, you are planning on applying base, then taping and applying more base, then removing tape and clearing? Depending on the base, you MOST CERTAINLY don't want to touch that base with wax and grease unless it is water borne. It WILL attach most bases.
Old 03-15-2009, 08:41 AM
Yes you clean before you sand, but cleaning after you sand and before you base is needed as well. That is where you use a weaker, faster flashing cleaner. If you had problems with it, it was likely because you used a slow flashing or too strong cleaner that stayed behind on the surface and you buried it under the base.
Old 03-15-2009, 08:59 AM
I am not shooting Base on Base, I am shooting base on old sanded ppg 2021. I was always taught to keep the surface as clean as you can, I have always in the past painted one color, I was just wondering if I should clean the area where the tape was, or not using wax and grease remover.
Thanks !!
Old 03-15-2009, 09:11 AM
If your substrate is the clear, or any other cured film such as the clear then yes use a wax and grease remover. I thought you were asking about cleaning an un-cleared basecoat.
what else in in wax and grease remover besides mineral spirits? Dubz Body - Exterior 47 06-19-2010 12:09 PM
Need to know max time between base coat applications. 4g64fiero Body - Exterior 4 08-25-2008 05:03 AM
wax and grease remover confused Body - Exterior 2 12-27-2006 07:57 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Help please-sanded through base coat fastblueheeler Body - Exterior 11 10-01-2003 07:32 PM
