before filler?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2006, 05:40 PM
Last journal entry: another pic
before filler??
I have researched and found that the consensus says to epoxy first then filler. OK, I stripped to bare metal and epoxied the panel. Now, should I scuff the expoxy with say 80 grit before spreading filler or can I apply directly over the epoxy without roughing the surface. BTW, the epoxy was sprayed over a week ago. Thanks in advance for any help you can offer.
Old 03-28-2006, 06:52 PM
Just scuff the surface of the epoxy with some 180 and it'll be fine.
The most common mistakes made by the newbe working with plastic filler. MARTINSR Body - Exterior 7 02-14-2006 10:21 PM
body filler esahlin Body - Exterior 18 02-12-2006 02:59 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
Body Filler do's & don'ts Ron M Body - Exterior 2 09-07-2004 05:00 AM
