Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Before i install if i could get a better cam choice
Old 11-20-2012, 11:07 PM
savage9scorpio savage9scorpio is offline
Originally Posted by techinspector1 View Post
Vinnie is no dummy, so yeah, it's possible.
What we try to achieve is a final drive first gear ratio of around 10.0:1.
A stock 'glide has a first gear ratio of 1.76:1, so if you married it to a 5.13 rear gear, the first gear final drive would be 9.03:1, still a little light....
An aftermarket 1.98 first gear in the 'glide and a 5.13 in the rear would make a launch ratio of 10.15:1, mo betta.....
this is the 1st time I've ever heads of gears higher than 4.11. with 5.13 gears if I'm cruising on the higheay where will my rpm sit? high or low. the ideal mph is around 70-75.
when I say drag racing I mean bracket. but Friday night grudge runs aren't out of the pic either. will 5.13's kill my gas more than 2.73's would.
