Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Before i install if i could get a better cam choice
Old 11-20-2012, 10:21 PM
idontdrivericeieatit idontdrivericeieatit is offline
Yes 5.13 would have alot higher rpm than 2.73 not sure where you would be as I dont use the power glides but if you want drag race at all you will not like that 2.73 thats a hwy gear and with glide you would probly be able run 80.in first. But you need to choose what you are doing with car is it for hwy or drag you will need different gears for each for hwy I wouldnt run 5.13 if I was worried about gas mileage I drive mine daily but drag it alot if im cruiseing along I might get 6 miles to gallon if im lucky when right foot gets heavy I can watch gas hand move
