Before i install if i could get a better cam choice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-20-2012, 11:42 PM
Banned
see thts a little overboard. I don't think I will ever see 7200 unless I'm doin some evil kennevil jumps with the gas pressed down in mid air. I just want a nice solid cam or another hyd flat tap tht gives a good power band. again the cam is rated 2 those rpms in a 350sbc the rpm drops some in a bigger displacement.
  #17 (permalink)
What the compression ratio of the engine as to low the cams not going to like it and what gear are you going run the 2.73 or the 3.42
  #18 (permalink)
Old 11-20-2012, 11:59 PM
And for me thats not overboard thats where the fun is but yes for you 6500 with stock bottom end is probly over board the 421 small block building now I plan on 8000 rpms but nothing is stock in my engines but need know what gear whats compression ratio and what cam do you want solid or hydraulic and I would use roller but that gets little exspensive as you will need retro fit kit to make rollers work I myself really like solid rollers but for rpms you will turn you could use hydraulic roller depense on how much money you have to spend if not much you are prob limted to flat tappet hydraulic but with way oil is going in long run you save money not having add 10 dollar bottle of oil additive every oil change with flat tappet hydraulic cams
400 cam
cam choice??? markzepp820 Engine 8 03-04-2010 06:05 AM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 9 12-01-2007 05:28 PM
cam choice derek32303 Engine 8 03-04-2007 07:32 PM
cam choice adrock430 Engine 4 02-08-2005 09:32 AM
302 install choice pzatchok Engine 4 05-29-2004 12:13 AM
