Before I make a cut - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2011, 09:13 PM
Before I make a cut
What is the proper way to cut the end here before I sew the facing to the cushion top? I want to avoid excess material and a lump in the facing I thought a 45 might help like I showed with he scissors
ID:	59439   Click image for larger version
ID:	59440   Click image for larger version
Old 11-04-2011, 09:17 PM
DanTwoLakes's Avatar
Wiki Edits: 22
This is a really good question! You can cut it on a 45 if you want, a lot of people do, but you will find that it is easier to lay the whole thing open without cutting it. Try it both ways, one side cut at a 45 and the other not cut at all, and you will see what I mean.
Old 11-04-2011, 09:21 PM
When you say lay the whole thing open I dont quite understand....Steve
Old 11-04-2011, 09:25 PM
Wiki Edits: 22
Look at the picture on the far right of post #14 in this thread: CLICK HERE That's what I mean by "laying open" the finished seam before sewing over it. This happens to have a welt in between, but it's the same idea.
Old 11-04-2011, 09:31 PM
Thanx Dan. I kinda figured that was what you meant but I figured it best to ask before I sewed it down. The pic is a great help........Steve
Old 11-08-2011, 01:44 PM
Last journal entry: Getting Started with Upholstery
I usually trim back that bulk so it lays flat once on the seat. Do you do something different Dan?
Old 11-08-2011, 02:29 PM
Wiki Edits: 22
I don't cut it back at all. If you cut too close you can screw up a seat cover or make it easier to pull apart. I've never had a problem leaving the excess, nor have I had a problem seeing or feeling any excess.
Old 11-10-2011, 08:59 PM
Thanx Dan, That worked well.
What are you doing to make it? dinger Off-Topic 14 05-12-2009 11:36 AM
how to make a 496 bbc 454cutlass86 Hotrodding Basics 8 02-12-2009 05:18 AM
What to do to make it fit?!?! tylerg85 Engine 0 09-21-2006 07:07 PM
Make your own? bigedd396 Engine 14 08-22-2005 05:49 AM
let us make this the last one qreturn Engine 4 09-16-2004 10:41 PM
