In The Begining - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2008, 06:37 PM
Cape Cod Bob's Avatar
In The Begining
There was a 86 sbc?
Here is where I will start. 60,000 out of a 2500 p/u. only been sitting a year.
Where are the #'s located on this. I looked at the front of heads and found nothing
It's going in this.
ID:	30313   Click image for larger version
Old 05-30-2008, 07:01 PM
Originally Posted by Cape Cod Bob
There was a 86 sbc?
Where are the #'s located on this. I looked at the front of heads and found nothing.
The VIN should be on the right (passenger) side of the block just ahead of the head facing up.
The block casting number should be at the left rear on the bell housing attach flange.
The head casting numbers will be bewteen the valve springs located under the rocker covers.
Looks like it's been used as a boat anchor on the Charles River, hopefully it isn't as ichy inside as it is on the outside.
Bogie
Old 05-30-2008, 07:07 PM
SSedan64's Avatar
Man that road salt did a job! What do you intend to use the engine for? Daily driver with fuel mileage or HiPer? If HiPerformance ditch the heads they're junk swirlports.
Old 05-30-2008, 07:20 PM
Hey, it turns over!
I just want to get it cleaned up and put it in to get the car running. ,then it will be a ride in progress. Just want to hit the local rod runs and go to the A&W DRIVE IN etc.
Yeah, the salt up here is murder. Even the bolts on my Jeep are rusting just from the salt air and it is only4 trs. old and been down south 3 winters!
Thanx Bogie.
Old 06-01-2008, 07:24 PM
I cleaned up the outside today. Pulled the plugs and found no oil on them. Take that as a good sign. A little surface rust on the end of some of the plugs. Pulled the headers and again found no oil, another good sign. Just a thin coating of carbon, same on the plugs. Good sign?
I could not find the vin# or any stamped #'s. Maybe a rebuilt?
Have the block #.
10054727 GM made in CANADA.
Where can I find out what the block 3's tell me?
Any other locations to look for vin #?
There are 2 senders. One on a port 1" above the oil filter.
The other on the pass. side down by the oil pan .Which is what?
Also found a leak ,crack in the oil pan, The outside is pretty rusty and I had it sitting on the pan for the ride home in the p/u.
I have a older pan that is better. '68. will they swap, or should I JB weld it for the time being.
Thanx for the help, Bob
Old 06-01-2008, 07:34 PM
Have the block #.
Without a VIN I can't get to an exact year but that's an 86 to 95 heavy duty truck block, 1 piece rear seal, with 2 or 4 bolt mains, given what it came out of I'd suspect 4 bolts till I knew better. No your old pan will not fit, the seal ends of the engine and the dipstick locations are not the same.
The sender by the filter is oil pressure. What your looking at on the pass side is probably a detonation sensor from the EFI system.
Bogie
Old 06-03-2008, 07:43 PM
The #'s on the head under the rocker cover is
14102193
where did my vin # go?
Thanx
Old 06-03-2008, 07:50 PM
SSedan64's Avatar
14102193
Thanx
14102193 305/350ci 1987-1995 1.84Itk/1.50 Exh
10054727 350ci 1986-up 155-205HP Car & Truck 2-bolt Passenger stick 1-piece rear seal
Vin should be on right passenger side of block just in front of head if your looking down. Unless the salt ate it.
http://www.chevymania.com/partsid/pa...p=head&block=S
Old 07-18-2008, 05:55 PM
update
all cleaned up, intake on with rebuilt(by me!?!) rochester,tranny on (another rebuilt by me?!?,both 1sts) ,installed ,lined up.
Next I need to set the pinion angle etc,.Thanx for all the help.
Old 02-03-2009, 05:58 PM
Update
Well ,in case you had not followed my thread on Q-jet problems, I got that motor running finally. But after about a total of 20 minutes and actually moving undr its own power it broke !
I found a piece of steel in #3 hole. The head broke and the piston too. To bad was running really good till that piece got in there. MMust have been in the intake port and did not come out with the cleaning I gave it. It would have to have fallen in while syored with the throttle body off before I bought it. I know, no excuse.
So, I am trying to locate another and try again.
begining of my rod playsinthedirt Hotrodding Basics 22 06-19-2007 11:04 AM
begining an old passion javajivegirl Introduce Yourself 1 02-27-2006 05:13 PM
This was the begining roys63 Hotrodders' Lounge 12 09-01-2003 08:21 PM
