begining of my rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2007, 12:01 AM
learning
begining of my rod
this sunday in welding class i made the cowl/firewall. i cut out the other body panes but did not get them fitted yet. ill do that this weekend.
let me know what you think so far
Old 05-02-2007, 05:03 AM
MrPhotographer06's Avatar
Krazy Kid
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
hey bud.. sounds good .. but what are you working on?
Old 05-02-2007, 06:40 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I think you are doing a good job. Keep us updated with your progress.
Old 05-02-2007, 07:00 AM
kruzr's Avatar
street rods forever
Looks good ,and your learning to weld,which is a plus for the project and your future.Do you have any plans or drawings of what its going to look like when finished?
Old 05-02-2007, 11:41 AM
learning
I did have a really sweet drawing, but i dont know what happend i 'll keep my eyes peeled. its going to be underslung in the rear, with the front springs off my toyota, this dude off craigslist is going to sell me a jag front end, i'm picking it up on thursday. its going to be a littel t-bucket. i have a 302 for it. thank you all for your support i'll let you know how it goes
Old 05-02-2007, 12:56 PM
learning
found it!
thats my insperation.
Old 05-02-2007, 01:04 PM
Krazy Kid
you plan to have the rear of the cab set up like that?
it looks great
i saw a t bucket like that recently when i was getting out the car..
xcept it had a blower on it.. and looked like a bigger than a 302 engine though
Old 05-02-2007, 01:13 PM
learning
only difference in real life though is that its not going to curve as much on the bottum, that would make seats really complicated. myabe though, i think it adds character
Old 05-02-2007, 01:15 PM
Krazy Kid
yeah..
well not really so much as being complicated.. just build a wood frame to fit it then attach it.. but wheres the gas tank going?
Old 05-02-2007, 01:48 PM
learning
gas tank will be in back some place, i'll either attach it to back of the tub or just make some brackets to put it onto the frame.
Old 05-02-2007, 02:04 PM
learning
ok i just got a really good idea: i can use shackles that bolt into the middle of the frame, and i could put spring hangers on top and bottum of the frame. then i could have it underslung for cruising and lookin cool, then flip my suspension upside down for max traction on the drag strip does this idea make any real world sense?
Old 06-05-2007, 12:46 AM
learning
ok finally got some camera action here...
i found a ferio front end, complete with breaks and rack and pinion. less complicated that ttb i decided. i might try to modify the sway bar tower to try and make it look nicer. it was at the end of a long day when i cut the channels into the body, so i measured the inside to where the outside should be so it does not quite fit. i will have to fix that later. tell me what you think...
Old 06-05-2007, 09:24 AM
seriousracer's Avatar
be a man dodge tree bark!
hm pics no work..
Old 06-05-2007, 11:01 AM
learning
dang they worked yesterday... why dont they work now?
Old 06-05-2007, 11:24 AM
work now...
thanks
Junkyard Motors.. Zartan Engine 20 07-08-2011 07:52 AM
rods kustumz Engine 13 02-07-2007 04:35 PM
destroyed con rod bearings - pics and description - what happened ? lowROLLERchevy Engine 36 12-06-2006 09:10 AM
Rod and piston question Ratoflic Engine 2 02-10-2005 07:34 PM
?? Bore Sizes ?? ss crazy Engine 2 10-03-2003 02:51 PM
