Beginner painter need advice. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-25-2004, 02:06 PM
May not have made a difference! Lacquer type products beat the VOC law by saying mix with acetone (no VOC'S) and thinner or urethane reducer is better but illegal for me to tell you that, so I didn't.
  #17 (permalink)
Old 10-26-2004, 09:20 PM
just picked up some omni torch red acrylic enamel i know this is some pretty shi**y paint but i got it for 118 with the reducer and hardener just to practice with. i just masked off most of my truck and shot the roof tonight it seemd real easy to shoot compared to that sealer i was paracticing with and it went down pretty smooth can someone tell me if i can buff this stuff out or should i wetsand with 2000 grit first? or would that mess it up also how long should i wait
  #18 (permalink)
Old 10-26-2004, 11:49 PM
Old enough to know better
Omni is just the lesser line of PPG. It is far better than any of the other "cheap" auto paints out there. I find it very easy to use and it's my default choice unless something else is required.
As far as the color sanding. If it is a solid color paint, you can wet sand a little and buff. If it is metallic, sanding or agressive buffing is out. The metallic flakes lay under a very thin layer of paint. Any attempt to color sand will likely expose them and the will begin to deteoriate.
  #19 (permalink)
Old 10-27-2004, 06:28 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
I never use anything finer than 320-380 before applying sealer.
Troy
If you don't make mistakes. your not doing anything.
69 SS/RS full custom Camaro 98 ISCA Grand Champion
69 SS/RS BB Camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 SS Chevelle BB conv.fresh frame off
26 T sedan street rod
