Beginner painter need advice. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2004, 03:27 PM
Ok i have an 85 c10 that i want to use to learn how to paint. About there motnhs ago my buddy helped me with the boddy work and we sprayed it with duplicolor primer with a spray gun. I finally got my compressor and gun and stuff and now i want to attempt to paint it. So what i am going to do is buy pretty cheap stuff for my 1st time. Today i went and bought a small can of duplicolor sealer . I sanded down the fender with 320 grit and sprayed it. It looks 10 times better than just the primer we put on there. I know it is supposed to be smooth and it pretty much is but there are a few almost microscopic bumps. The can says non sanding. How can i correct the bumps or will the paint lay smooth on top of that. I plan on using acrylic or urethane enamel.
Please dont flame me for using cheap paint . Im just using it to learn.
Old 10-24-2004, 04:38 PM
1957ford's Avatar
If it don't go Add Horsepower!
Non-Sanding just means you don't have to sand as long as you recoat within the recommended window. If there is a blemish, just let the sealer completely dry, then sand as necessary. You will have to re-seal before you paint. You should also finish sand with a bit finer grit paper at least 400-500 grit. Some people go as fine as 600. You should also get the P-sheets for the products you are using. These will tell you exactly what you can and can't do with the product.
Old 10-24-2004, 04:45 PM
how smooth should it be? it is pretty smooth but not as smooth as glass its hard to explain kind of like it has a small texture to it
also if it comes out good could i use a clear coat over the urethane?
Old 10-24-2004, 04:48 PM
BarryK's Avatar
Also to add to 57's info, considering the type of primer / sealer you have on the car a smarter choice in paint would be an acrylic enamel to prevent lifting. Only other thing I would add is spend the money on a good hardener so if you need to redo a panel you won't have any sensitivity period to worry about.
In other word I would buy the cheapest paint such as Omni or Nason and buy the hardener for Delstar or Centari.
Than mix 8:1. This way you can make repairs till your a pro and it won't break the bank account.
Old 10-24-2004, 04:52 PM
ok oreilleys sells nason for 110 a gallon is that a good deal? what exact kind of hardener would work well with it? and about how much paint would i need? its a shortbed and i wont be painting the inside of the bed
Old 10-24-2004, 04:58 PM
1957ford's Avatar
I totally agree with Barry. The hardner for Delstar is DXR80. You will need a pint of that for a gallon of paint. A gallon should be enough for about three coats without the inside of the bed.
Old 10-24-2004, 06:37 PM
how much for the delstar hardener?
also would it be possible to mask of some racing stripes ? i want red paint with white stripes(just an idea) or would i definitely have t o use a clear coat to get rid of the line where the colors meet or could i just wetsand? also would it be better ti pain the white first and then mask it?
1 more question.. would i have better luck with using a BC/CC? i hear it is easier to fix mistakes. is the price about the same except i have to buy a gallon or so of clear?
Old 10-24-2004, 07:56 PM
1957ford's Avatar
Last time I looked, I think the hardner was about $40/pint.
Yes stripes are always possible, just have to wait at least 10 hours before you mask (enamel w?hardner).
You will have a line if you use just enamel. Not really feesable to wetsand the line to get smooth. Line will fade lose crispness.
Would be easier to paint stripe colors first, less to mask off.
BC/CC definately better, easier, and faster to get colors on, but pretty pricey.
If this is just practice, I would suggest practicing with what you will want to use on the real thing.
Most paint shops have a mistint pile you can get off colors pretty cheap.
Old 10-24-2004, 08:51 PM
so for bc/cc i would need about a gallon of paint a gallon of clear and what else just the hardener what kind of prices am i looking at.
Old 10-24-2004, 08:56 PM
1957ford's Avatar
Depending on color, Red is more expensive, between $250-$500.
Old 10-24-2004, 08:58 PM
well i definitely want to stick closer to 250 , i can afford that can someone do me a favor and make me a list of what i will need brands too, that way i can go tommorrow to the paint supplier with the list and check it out.
Old 10-24-2004, 09:01 PM
1957ford's Avatar
You need to see if that sealer will let you put BC/CC on it before you go to the store. I am not familiar with that brand, so am not sure if it will work. BC/CC uses a stronger reducer, and could lift that sealer.
Old 10-24-2004, 09:06 PM
well i just got like a small 1 quart can to practice with im not set on using it. Just add the sealer i need to the list please
Old 10-24-2004, 11:01 PM
the only thing i can really use as a basis for what it will cost me is the House of Kolor site for a BC/CC with a primer sealer, reducer and hardener would cost about 400 bucks how much cheaper would a different brand be does nason carry bc/cc bc i have only seen the urethane and enamel cards
Old 10-25-2004, 01:46 PM
oops i was out practicing with that sealer and my dumb *** accidentally mixed it with reducer instead of acetone it looks kind of powdery oh well at least i am getting practice
