Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Being told my radiator / oil cooler setup wont flow properly ...
Old 10-05-2011, 02:07 AM
lowROLLERchevy's Avatar
lowROLLERchevy lowROLLERchevy is offline
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
what do you guys think ?
radiator in the normal spot. Intercooler in front of it. 2 oil coolers laying flat
in front of them, Stock air damn chucked in the trash. car converted from
"bottom feed" to "front feed" by cutting a fat hole where the plate used to
mount and chucking the fogs next to the airdamn (and the stock radiator
ducting for that matter too)
i dont see the problem? big hole catches air while driving forward. air
escapes any way possible. Takes heat with it.
agree / disagree ?
I was told:
airflow would go downward through those coolers only if you put an airdamn at the leading edge of the bumper so no air can get under it...
I agree that an air damn would HELP flow, but not having one isnt going to cut off flow for some magical reason.
