Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Being told my radiator / oil cooler setup wont flow properly ...
Old 10-05-2011, 01:07 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Years ago, a fellow named Bill Thomas was modifying and racing Corvairs. They removed the sheet metal under the motor to remove some weight from the car and the motor began overheating. They found that without the panel, air coming from the front of the car made a 90 degree turn up into the motor while the fan was trying to blow air downward through the motor. Result: stagnation of air and no cooling going on. As soon as they re-installed the panel, the motor ran at its usual temp.
