Bellhousing - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2010, 07:40 PM
Bellhousing
I'm just curious what bellhousings are compatable for a 64 model 289 or a 292?
Old 11-21-2010, 07:50 AM
Wiki Edits: 27
sbf bell
Ford changed the Small block bolt pattern The 221 -260 bell housings are different than 302' I "am not sure when the small block changed I know later 289 are the same as 302, I am not sure about. early 289's. early Ford 239-272 292 312 Y blocks are an entirely different family . The Y block machinery was used in the manufacture of the small blocks so some dimensions are the same. with some welding and machine work a Y block truck forged steel crank can be made to work in small block.
Having trouble finding the right GM bellhousing gearjammer38 Transmission - Rearend 10 07-07-2010 01:35 PM
4L60E Bellhousing Change slydelon Transmission - Rearend 2 06-01-2010 01:18 AM
3 manual speed gearbox on a flathead: which bellhousing can i adapt? Jean Phi Transmission - Rearend 2 03-13-2008 03:54 PM
TH350 Bellhousing Broken BrandOmatic Transmission - Rearend 6 09-28-2006 09:29 PM
Lakewood bellhousing shagginwagonvic Engine 6 02-13-2005 04:51 PM
