-   -   Bellhousing for 402 bb (http://www.hotrodders.com/forum/bellhousing-402-bb-60793.html)
70camaro804 04-03-2005 11:07 AM
I am changing a 70 402 bb to a 4 sp. the flywheel is or will be 11". Will this take any GM bellhousing for that year or is there a certain bellhousing I should be looking for. Also the same for the flywheel.
poncho62 04-03-2005 11:28 AM
Big Block and Small block bellhousings are the same pattern. The flywheels will also interchange.
jimfulco 04-03-2005 09:23 PM
Some vehicles require a different bellhousing from others due to clutch linkage placement, etc. If you're using the 11" clutch, you'll have to use the larger 168-tooth (14" diameter) flywheel, and that wheel won't fit into some of the smaller bellhousings that were designed for the 153-tooth (12-3/4" diameter) wheels. For example, first-gen Camaros used the small bellhousing with casting number that ends in -403, or the large housing with a number that ends in -621. The 11" clutch won't fit with the -403.
Another potential difference in bellhousings is the size of the hole where the transmission front bearing retainer rides. I don't remember the exact dimensions, but there is a small difference which can cause misalignment if the hole is too big.
packratwrecker 04-04-2005 12:03 AM
As far as I'm aware, there are only 2 sizes of front retainers. The 'car' retainer is smaller, and more popular. It is also the same size as the retainers used on the old SM318 3-speeds, in cars or pickups.
M&M CUSTOM 04-05-2005 07:07 AM
4-1/4", 4-11/16", 5-1/8"
Found HERE.
