which bellhousing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2005, 03:01 PM
which bellhousing
hi guys,
i'm doing a 4-speed conversion on my 72 chevelle. i'm using a 10.5" clutch with a 168 tooth flywheel which is right around 14" in diameter. i went to bolt on my bellhousing, which is the casting number ending in 403. well, the bellhousing won't clear the flywheel. do i need to get a bellhousing for the 11" clutch to make this work? if so , can you recommend a casting number for me? i'm going to a swap meet next weekend and would like to get the correct one. thanks for any help.
Old 06-25-2005, 11:07 PM
MI2600's Avatar
Member# 3287
That flywheel sounds way too big for a 10.5" clutch.
Try this site:
www.tracyvette.com/bellhousings.html
Old 06-26-2005, 08:15 AM
thanks for the site
Old 06-27-2005, 10:41 AM
Last journal entry: PICTURE TEST
bell
If you are running a 168 tooth flywheel you will need the bigger bell. Just as a warning some of the bells that will clear that flywheel are through the roof in price...... you may want to keep your eye open for a blow proof....
I am not sure if this is a stock car or something you plan on racing????
Keith
Old 06-27-2005, 06:39 PM
keith,
it's just going to be a street driven car. i'm going to keep an eye on ebay , and check out the swap meet this weekend. if i can't find something reasonable , i may just get a blow proof. big bucks , but my feet may thank me some day.
Old 06-27-2005, 07:26 PM
MI2600's Avatar
Member# 3287
Try local boneyards. I picked up a couple of larger bellhousings for $5-$10 a few years back for the '67 from a yard. I recently found out they were 621 castings and are selling for $200+ on Ebay!
Old 06-29-2005, 07:13 PM
http://rickscamaros.com/cgi-local/So....htm?E+scstore
Look in the clutch section for the 621 bellhousing.
Might also try www.kajunjon.com
Old 06-29-2005, 08:02 PM
thanks for all the help guys. i'm wondering if it wouldn't just be cheaper and easier for me to get the 153 tooth flywheel and use the bellhousing i already have? i'll see what the swap meet turns up this weekend.
Need Help With Bellhousing 70camaro804 Transmission - Rearend 1 04-27-2005 10:39 PM
Lakewood bellhousing shagginwagonvic Engine 6 02-13-2005 05:51 PM
Need help on bellhousing raidmagic Transmission - Rearend 13 12-21-2004 11:33 PM
Bellhousing Question JamesRS Transmission - Rearend 7 11-15-2004 10:06 AM
Richmond T10 and a Lakewood bellhousing - Inadequate fork adjustment dannyboy02 Transmission - Rearend 7 12-20-2002 06:27 PM
