bellhousing bolt torque to motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2008, 01:50 PM
what is the torque for bellhousing to motor bolts? It is a th350 to chevy 350. Also I so far can only get 5 of the 6 bolts in. I am not able to get to the upper passenger bolt. Any suggestions, I do not wont to take it out.
Old 02-14-2008, 03:42 PM
MI2600's Avatar
Member# 3287
According to the below site, it's 30 ft/lbs:
http://www.torkspec.com/torkspec.aspx
Old 02-14-2008, 04:05 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
good question on the bolt torque, as to the one bolt not wanting to go in. Assuming you know the hole is clean, no broken bolt in there. I would run a tap in just to clean the threads up could just be crap in there or the first few threads a trashed and the tap would clean that up also.
Old 02-14-2008, 06:34 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Let's see.....my impact gun with my three foot extension and wobble socket goes.....ZRRRRRRRRR--BRAAAAP, and I usually give it an extra BRAAP-BRAP.
You can lower the tail of the tranny to make it easier to get to that last bolt. Make sure the threads are clean like PEPI suggested using a tap for the hole and a wire brush, thread file or tap on the bolt. Your dipstick tang is straight and not keeping the bolt from going in straight isn't it?
Old 02-14-2008, 06:39 PM
life is a temporary assignment
I have always torque mine by hand,And never had a problem.
Old 02-14-2008, 08:01 PM
Jmark's Avatar
As far as missing one bolt, never been a problem for me. Had some that even came in the shop missing,,,,,,and went out missing too! LOL
Mark
Old 02-14-2008, 08:19 PM
poncho62's Avatar
Wiki Edits: 5
The bolt came out, it will go back in........just need fingers with an extra knuckle sometimes....or tape the bolt to a wrench.
Or...once the engine is bolted in....you could drop the tranny mount to make more room to get that bolt in.
Old 02-14-2008, 08:29 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Why can't you not get to it? I use a 24 in extension and a wiggle socket.
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 10:21 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
Oil pan bolt torque longt Engine 4 03-17-2006 04:38 PM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 09:04 AM
