Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bellhousing broke in two
Old 06-13-2009, 09:40 AM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
I would check driver side engine mount, and the trans mount if the trans mount is good leave it if the driver mount is good or bad change just that side to a solid mount (DRIVER SIDE ONLY) and also check the drive shaft make sure its not to far into the tailshaft of the trans. And also check for proper pinion angle on the rearend. I am thinking it is from engine flex. I bet it busted from the starter around to the other side am i right? Hope this helps Cole
