Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bellhousing broke in two
Old 06-13-2009, 01:31 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Originally Posted by keesey1985
i cant use the side mount no room because of the steering.
can i just buy the mount plates that go between the block and the trans, that mount to the frame. i thought befor i put it in there the fist time that i should have but i think i will now.
You don't want to mount the engine/trans in 3 places.
I'd either figure out a way to fab a custom mount from the frame to use the mid mounts, or make some reinforcing bars to go from the trans to the motor. Even if you picked up 2 or 3 pan bolts on each side of the pan and motor and bent up a piece of 5/8 solid rod to bridge between them it would help.
Later, mikey
BE different....ACT normal.
