bellhousing broke in two
what would cause my bell housing to crack all the way aroung from passenger side to driver side?? well its more than a crack it split in two!!
tranny problems
I had the front bearing in a 37 lasalle box lock up and that big heavy gear shift stick was beating the steering column and my leg ...the bell housing was scattered along the road. in a lot of little pieces.
Gonna need a LOT more info. What car, trans, what kind of motor and trans mounts, what driveshaft, what motor etc...
what vehicle? broken bell housing from chassis flex, broken engine mounts, vibration , broken trans mount, abuse like desert jumping a truck. |
chevy 327 .30 over, flat top 2 valve cut pistons, lunati bracket master 2 cam .480be .480 at 230 dur, 1.6:1 roller rockers, weind air gap intake, headers, 3 inch exhaust, 3200-3500 stall converter, new flywheel, red alto discks and kolene steels, fairbanks valve body reprograming kit, 3.89 gears and a full spool, 295 50 15 tires, new front motor mounts and new energy suspension trans mount.
all of this is in a 1934 ford flat bed pick up. |
I would check driver side engine mount, and the trans mount if the trans mount is good leave it if the driver mount is good or bad change just that side to a solid mount (DRIVER SIDE ONLY) and also check the drive shaft make sure its not to far into the tailshaft of the trans. And also check for proper pinion angle on the rearend. I am thinking it is from engine flex. I bet it busted from the starter around to the other side am i right? Hope this helps Cole
right on the way it cracked. trying to get some picks up. the front mount is almost solid its a fairly stiff rubber plastic material. and the trans mount is a energy suspension mount. drive shaft is not to long, but i am getting a fair amount of wheel hop and axle twist on launch drive shaft hits fuel tank,
what are my options i have seen replacement bellhousing but you have to cut this one off and the new one mounts to the front pump. any opinions |
1 Attachment(s)
Are you using the front mounts by the timing cover, or the mid mounts under the second exhaust ports?
Bellhousings typically break when you use a front mount and a trans mount on the tailshaft of the trans. Hanging all that weight from the far ends puts too much stress on the bellhousing. These style mounts are supposed to be used with the trans mounts that are on the bellhousing. http://www.hotrodders.com/forum/atta...id=38731&stc=1 Later, mikey |
front by the timing cover and the tail shaft mount on the trans. it was like this for 8 years and never had a problem till i rebuilt everything. i am getting my camera will get pics up right now.
Here is your problem.
http://i463.photobucket.com/albums/q...7/DSCF0081.jpg You need midmounts. It took 8 years to break your your bellhousing, some last longer than others. The midmounts are closer to the center of the weight of the block, which takes the stress off the bellhousing. It's been a well known problem for many years. The frontmount motormount was designed to use a transmission that was mounted at the bellhousing. All of the stock applications that used the front mount were set up like that. I have thought about making some reinforcement bars that went from the block to the trans for those who don't want to use the right mounts, but never had the opportunity. Later, Mikey |
i cant use the side mount no room because of the steering.
can i just buy the mount plates that go between the block and the trans, that mount to the frame. i thought befor i put it in there the fist time that i should have but i think i will now. |
I'd either figure out a way to fab a custom mount from the frame to use the mid mounts, or make some reinforcing bars to go from the trans to the motor. Even if you picked up 2 or 3 pan bolts on each side of the pan and motor and bent up a piece of 5/8 solid rod to bridge between them it would help. Later, mikey |
Also I would investigate curing the wheel hop and axle flex as when that happens it places an incredible amount of stress on the drive train which shows up as broken motor mounts and bellhousings..
Sam |
| All times are GMT -6. The time now is 01:12 AM. |
