Bellhousing dillemma... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-19-2013, 03:21 PM
Oval track pans usually only pick up on the right(pass) side of the pan.
The PRO/CAM pan should work with any mini starter, I would go with it.
  #17 (permalink)
Old 05-19-2013, 03:33 PM
So I can use an oval track one then. The Pro/Cam is the 1st one I posted, the 2nd gold colored one is a Milodon road race one, about $100 more.
  #18 (permalink)
Old 05-19-2013, 03:43 PM
Unless you plan on making some long high speed right hand turns, the P/C pan will work fine. The road race pan has no pickup provision on the left side either.
  #19 (permalink)
Old 05-27-2013, 09:44 PM
Well exhausting all options and realizing that the way the frame of my car was designed, without major modification to the mounting of the steering rack or cross member, I can not fit a conventional style oil pan or any of the easily available dry sump ones. Also I called a few of the manufacturers and they assured me they do not fit with a block mounted starter. Sooooooo, this is my easiest and cheapest solution to the problem. To modify the oil pan that I already have to fit the block mounted starter. Im not thrilled to have to do this, but like I said, my easiest alternative. I needed just over 1/4" of clearance so I cut out a section and will be able to fit the 3rd sump in a similar location as to where it originated without changing performance.
Currently the pan is at my buddies getting welded up. Thanks for all yall's input..
ID:	74370   Click image for larger version
55 Chevy QTR dillemma. tech69 Body - Exterior 66 04-20-2013 09:34 AM
What bellhousing do I have? curtis73 Transmission - Rearend 2 04-02-2011 10:16 AM
Head dillemma, is it worth it (brodix IK or Holley systemax kit) eatonde Engine 8 09-11-2008 08:09 PM
Bellhousing bobinida Engine 1 07-29-2007 11:17 AM
bellhousing fordriffey Transmission - Rearend 1 01-06-2003 03:47 PM
