Should work, not absolutly sure...............
I would suggest you bite the bullet and get an aftermarket scattershield. If you are going to abuse it, it's much easier on the feet.
Ontario Rodders |
An aftermarket steel bellhousing would be the easiest and safest. Unless you are doing a numbers matching car, I wouldn't worry about the proper casting number. |
Thanks for the reply's all. I just wanted to add a little more info, the Trans that I have is a Borg Warner Super T-10 out of and early 70's Camaro. The Trans that Chevy started using after they dropped the Muncie's. I believe that it has the same dimensions as the Muncie. They both have the "Big Hole", but I was curious as to whether or not they would fit in my trans tunnel without issues, and if I would have clutch Z-bar problems.
