Bellhousing removal from 55 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2013, 03:19 AM
Hi,
I am removing the gearbox from my 55 2nd series pickup. I have the tailshaft out and gear box removed. I have unbolted the bellhousing but cannot get it out past the bellhousing mount crossmember. Am I doing something wrong or do I need to tilt the whole engine to get it past this?
Any help would be appreciated.
Thanks
Mark
Old 09-07-2013, 06:10 AM
poncho62's Avatar
Wiki Edits: 5
I take it you have the engine supported, as the front mounts are right at the front?
Might be easiest to move the engine forward to give some room, but I am thinking if its a six cylinder, you arent going to have much room to do that unless the rad etc comes out too
Old 09-07-2013, 08:32 AM
RWENUTS's Avatar
Guess what!!
You need to remove the motor to get it out. Designed that way!
I think the engineers thought it would never need to come out. They did make that clutch inspection cover big enough to get the clutch out though!
Old 09-07-2013, 07:37 PM
Thanks fellas. It's a 283 v8. Was hoping not to have to move the engine but looks like i will have to.
Old 09-08-2013, 06:45 PM
cal1320's Avatar
I've had mine (56) out while the engine was installed several times. Remove the bell housing mounts and elevate the rear of the engine. There is plenty of room to remove the bell housing. Watch the radiator/fan clearance. Mine had no issues.
Are you doing a T5 swap?
Old 09-09-2013, 07:19 AM
Thanks. Ill give that a go. Actually doing a t56 swap. I hope It goes ok as I haven't read of too many being done. No doubt ill be posting a few more questions quite soon.
Old 09-09-2013, 05:41 PM
poncho62's Avatar
Wiki Edits: 5
Thing is, if you are not using the bellhousing with the mounts, you will have a real long distance from front to rear mounts.....Would be best to put side mounts on the engine...a lot less stress on the aluminum bellhousing
Old 09-09-2013, 07:12 PM
cal1320's Avatar
Poncho is right. Too much distance from the front mounts to a rear trans mount. Adding side mounts while the engine is sitting on the factory mounts is easy. I have the T5 with a 3.42 rear gear and really cant use 5th until 55mph or so. I can't imagine needing another gear.
The Following User Says Thank You to cal1320 For This Useful Post:
AutoGear (10-24-2013)
Old 10-23-2013, 03:29 AM
Thanks fellas, ended up removing the engine and have gone the side mount option.
Old 10-23-2013, 08:24 AM
If you need the Hyd clutch parts, or decide to go mechanical, the guys at Hawks Third Gen Parts can help you out. They swap these gearboxes into all kinds of things. If your trans was indeed converted from an LT style to an LS Style, do you know if they changed the front mounting plate on the transmission? This uses a concentric throw out bearing assembly that the input gear passes through; you really need to use an LS bellhousing for this setup because the LT and LS have different length maindrives (input gears).
Old 10-24-2013, 02:40 AM
thanks for the advice
55 chev pickup truck
chevy bellhousing help michaelangelo327 Engine 10 11-09-2010 09:04 AM
chevy 2 bellhousing 65novamt Transmission - Rearend 0 07-28-2010 04:30 PM
driprail removal on a 54 ford pickup 1954sheila Body - Exterior 2 01-13-2010 10:32 AM
Chevy bellhousing Cliff.E Transmission - Rearend 1 05-14-2009 05:16 PM
Chevy Bellhousing #s help please 49T&C Transmission - Rearend 4 05-28-2004 02:07 PM
