belt - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2005, 03:48 PM
delsman's Avatar
belt
heres a stuiped question im putting on a new belt for the fan and power steering, cause it blew on me but heres the thing i got it on and now the fan doesnt work as well as the power steering. i only have it around two of the pullys i just want to make sure that it is on right or does it have to go around the balncer or the fly wheel what ever they call on the bottom of the engian
Old 08-15-2005, 04:13 PM
poncho62's Avatar
Wiki Edits: 5
Yes....it should also go over the crank pulley. Was it not that way before the belt went bad?
What engine are we talking about?
Ontario Rodders
Old 08-15-2005, 04:16 PM
jesse01's Avatar
mini me
around your crankshaft pully?
umm yeah i belive so
what kinda of car we talking about here?
it should go around the crank pully to the water pump pully(which your fan is connected to) and your power steering pully
is the belt tight?
is it a clutch fan?
does the car run hot?
is there any other belts going around the water pump pully? or does it just have a single groove in the pully where you can only put 1 belt?
J
Old 08-16-2005, 11:14 AM
delsman's Avatar
is the belt tight?
is it a clutch fan?
J
i got it thank you for your reply but i dont know if it runs hot it is a ford 150 1978 the heat gauge isnt hooked up and i cant find where to hook it up i never did any wiring before that and the tac i wuld like to put in to but hav no idea where that gets hooked up to
Old 08-16-2005, 11:20 AM
delsman's Avatar
belt
thank you guys for anwering me back i figered it out after 4 tries i got the right belt every one was to thick thank you agian
Fan belt problem on rebuilt 406sbc 406chevelle Engine 9 06-28-2008 10:53 PM
Squeeling Fan Belt - Out of true Pulley Billy Boy Engine 3 02-15-2005 06:51 PM
Timing Belt ap0001 Engine 2 09-20-2004 10:22 AM
will i keep throwing my belt? uneedmorethen10s General Rodding Tech 4 02-03-2004 09:49 PM
belt breaking all the time oldcarguy85 Engine 14 01-14-2004 05:38 PM
