belt diagram - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2012, 12:12 PM
belt diagram
I changed from a two belt system to a serpentine belt system using mostly 1984 brackets on my 1934 street rod with a Ford 302 v-8. It has AC, power steering and electric fan. Now I am having overheating problems at idle. I think I may have reversed the rotation of my water pump. How can I know for sure and what do I do to correct the problem?
Old 07-25-2012, 08:49 PM
Cape Cod Bob's Avatar
You probly did. On Chevies the serp, dr. engines the water pump is different. I assume Ford may be the same. So, you may have to get a newer pump made for sep. dr.
Big block V belt diagram Gordo84 Engine 1 07-26-2011 12:44 PM
Drive belt Diagram Chevy 84 General Rodding Tech 6 12-07-2007 08:49 PM
where can I get an online belt diagram quad 4? F&J Engine 3 07-16-2007 08:02 PM
alternator belt diagram NEEDED! StudebakerBob Engine 2 01-29-2005 11:53 AM
'94 Skylark Serpentine Belt Diagram '77 Regal Engine 0 03-03-2004 07:45 AM
