Belt driven Turbo??. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2013, 02:54 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Not a turbo guy myself.Curious about the aftermarket belt driven turbo's.The good and bad.
Old 10-23-2013, 03:49 PM
malc's Avatar
Living At The Speed Of Life
I thought turbos are exhaust driven, superchargers belt driven.
Show us an example.
Old 10-23-2013, 05:04 PM
spinn's Avatar
Does Gary mean something like this?
This from ATI , or something. Not mine.
Old 10-23-2013, 05:37 PM
Braddi's Avatar
Show us an example.
Thought so to.
Old 10-23-2013, 06:35 PM
Rhansen's Avatar
Footbraker
An old friend of mine runs an ATI setup on his 69 GTO. 421 (or 428 - I forget), blow thru carb setup w/6 psi of boost, stock iron heads, unknown (to me) cam, 2500 stall, 9" rear, 3.00 gear, th350, 28" tall tires, 6k redline, full interior street driven not optimised for the dragstrip and he has to use a throttle stop to keep it below 11.50 since it has no cage (60' time in the 1.6 - 1.7 range).
Early on he had some tuning issues and burned up 3 pistons (lean on the top end) but got it all sorted out and the car has been very reliable since then.
Old 10-23-2013, 06:46 PM
Proud LOSER
That's a procharger.....a centrifugal supercharger.
Not a belt driven turbo....they work well....drove a fox body deep into the 12's with procharger, gears and exhaust and nothing more.
Old 10-23-2013, 07:03 PM
ProStreetRob's Avatar
5.7L S10 LS SS
In definition a turbocharger is powered by a turbine that is driven by the engine's exhaust gas
And in definition a supercharger is mechanically connected to the engine's crankshaft by means of a belt or gear.
Now what your talking about is a centrifugal supercharger. Some people see it simply as a belt driven turbo because basically it is. Like a Turbo it's also powered by a turbine but instead of being powered by the engines exhaust it's connected to the engine's crankshaft by means of a belt or gear.
I put a Centrifugal on my old 99GT Stang, here's a few pic's
ID:	92226   Click image for larger version
ID:	92234   Click image for larger version
ID:	92242   Click image for larger version
Old 10-23-2013, 07:04 PM
1Gary's Avatar
I honestly didn't know what a Pro-charger was. Searched and found this:
ProCharger Carbureted Chevy Systems
Old 10-23-2013, 07:05 PM
Rhansen's Avatar
Footbraker
I know it's a procharger, just assuming that's what Gary was really asking about since I have never heard of a belt driven turbo.......
Old 10-23-2013, 07:12 PM
Proud LOSER
Ahhh, fair enough
Old 10-23-2013, 08:29 PM
Gary these things with a centrifugal compressor like the Procharger or turbo-charger are both examples of using a centrifugal impeller to generate air flow with pressure. How that compressor is driven gets into the naming.
You vacuum cleaner uses a centrifugal compressor powered by an electric motor. The Pro-Charger takes its power from the crankshaft like a classic GM Roots blower using a belt to make the coupling. The "turbo" powers its centrifugal compressor by ducting hot exhaust gases into a turbine on a shaft common with the compressor.
Quite literally a turbo jet engine is little more than a turbo-charger with a combustion chamber where the piston engine would have been. In fact a turbo charger can be used to make a turbo jet engine, it just doesn't last long doing that because of the temperatures of jet exhaust against the turbine.
Bogie
Old 10-23-2013, 09:16 PM
1Gary's Avatar
I do know about (somewhat) about turbo's.Yrs ago I did the wrenching on a friends ET GN.It was the belt driven part I wasn't sure about at first.Do think it is neat idea.Maybe doesn't take as much to drive them as a roots.
Old 10-24-2013, 12:07 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Originally Posted by Braddi View Post
Thought so to.
When I was young they were called "turbo-superchargers" and sold under that title and later the slang term turbo charger took hold and this day and age just the term TURBO has caught on
A supercharger is any device that pressurizes the air intake to above atmospheric pressure. Both superchargers and turbochargers as they are called today do the same thing. As a fact, the term "turbocharger" is a shortened version of its official and original name "turbo-supercharger" Designed and most valuable on WW2 planes! Whether a belt drives the turbines impeller or electricity or the exhaust of an engine its still a turbo-supercharger
Jester
Old 10-24-2013, 01:30 AM
Whether a belt drives the turbines impeller or electricity or the exhaust of an engine its still a turbo-supercharger.
Sorry in my last post that should read:
Whether a belt drives the turbines impeller or electricity or the exhaust of an engine its still a supercharger
Jester
Old 10-24-2013, 06:21 AM
5.7L S10 LS SS
I'm a supercharger nut, I've had 8 Supercharged Vehicles now and have used @12 different types and sizes of Roots & Twin Screw Superchargers. Once you experience the absolute INSTANT power you will be hooked for life
What makes a Centrifugal Supercharger a little different and a great choice (especially as an add on to a vehicle that wasnt made for a supercharger).
IS they have small ones that you wont even know are there under normal driving yet they will increased power and maintain OR BETTER you MPG.
And when you stomp it to the floor the difference in power is just mind blowing. For example my old 99GT had a pathetic 235/270 to the rear wheels and when I put the smallest Procharger made on it (P-1SC at 8-9 lbs) it went to 385/385 rear wheel. Thats @ a 60% increased in power and I installed the entire mess one Sat all by myself. They also offer units like the F-2 at 23 lbs that will increase your power over 200%, (but you better be built for it). And yes they are clearly less stress on the motor that a Roots or Twin Screw
How much hp do belt driven accesories use up xzero117 Engine 2 02-12-2013 03:57 PM
Unexplained Vibration - Belt driven accessory? Torque454 Engine 3 01-09-2011 11:55 AM
Direct drive or Belt driven mikeweb Garage - Tools 18 07-16-2007 12:09 PM
Electric Vs. Belt Driven Water Pump AustinG Engine 6 07-22-2006 09:32 AM
eletric fans or belt driven???!!!???!!! Fred West Hotrodding Basics 7 12-21-2005 11:32 AM
