Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - belt squeal
Thread: belt squeal
Old 09-13-2012, 12:50 PM
Dmgarage Dmgarage is offline
thanks Bogie, this is the same truck I was having the cooling issue with. I got a Griffin rad 31"x19 2 rows of 1.25 tubing. that should solve that. When its apart Ill clean up the pulleys & try new gates belts. I had another belt that ran from the crank around the water pump around the power steering and to the ac compressor on the other side. I still had the squeal then too. I had taken it off before I took the pic trying to isolate the problem
