belt tensioner assembly
I'm kind of new to Ford's but now have an old F-1 with a 302 Mustang HO '85 engine. Trouble with the serpentine belt & alternator and wondering if the heavy belt tensioner assy could be the cause?? Mine moves with some force but wondering if they should move freely??
Remans are usually thrown together from a common pile of parts, i.e. thay pay little attention to what the exact fit was on any one car. So this problem was present before replacing the tensioner? |
I'm not sure what you mean... is the belt under the tensioner touching itself where it goes aroundthe W/P? If this is the case, try a slightly shorter belt. |
Check your belt installation, on some models there is more than one way to route the belt. You can usually tell the correct orientation by the way the belt rides on the individual pulleys, ribbed side always rides a ribbed pulley. Smooth pulleys always see the smooth backside of the belt.
Worth a look see. ;) |
Bringing this back up for closure. I'd like to think that when one posts a problem, you should also provide closure so that the solution is open to everyone, even if its simplistic!! So, the belt started rubbing on itself due to a loose alt. pulley . It rounded out the hole enough to let the belt touch itself. So, I got another pulley & went through a belt trial fit ... then I found out that the pulley I'd bought, despite being same diameter across the outer, is about 3/8" under when you mike the inside where the grooves are!! Turns out that 4 cylinder pulleys are under enough to let the belt touch itself while the proper 5.0 liter Mustang pulley gives you JUST enough room when the tensioner comes down. Serpentines are not adjustable with slide grooves so the pulley size is critical! Looking back its easy but like so many things in the sport when you start crossing up stuff for your hot rod , its NOT!!
:thumbup:
Thanx For The Post! Appreciate your sharing what you found... |
| All times are GMT -6. The time now is 10:31 AM. |
