Belt throwing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2012, 04:22 PM
Belt throwing
Hey guys, can't keep the belt on my '89 k3500 4x4 454 c.i. Rebuilt the engine and installed long tube headers and kept the air pump but not hooked up. The pump sieved so I pulled it and ran a shorter belt. Can't keep a belt on it. Replaced tensioner. Tried every belt between 60" and 85". Still throws belts. I don't want to run an air pump that's not hooked up. Any Ideas?
Old 08-18-2012, 06:22 PM
Just guessing here, but maybe the rubber in your balancer is coming apart and letting the pulley walk forward causing the belt to also walk off. Happens to some of my high torque hotrods sometimes.
Old 08-18-2012, 06:50 PM
Make sure pulleys are aligned. Even slight out of alignment will throw belts.
Old 08-19-2012, 05:57 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 on this .
Cole
Old 08-19-2012, 08:52 AM
Wiki Edits: 27
slow it down
In the 60's that was a common problem when you pumped up a SBC, the Fix was to get the smaller corvette pullies to slow the belt down
Old 08-19-2012, 01:23 PM
Hey guys, thanks for the replies. Balancer is new. Any tips on checking the alinement of the pulleys?
Old 08-19-2012, 01:48 PM
Check with a straight steel rod it should fit flush with the inner groove on the crank pulley and the inner grove on whatever pulley you're checking at the same time.
Old 08-19-2012, 04:40 PM
Hey thanks. I guess it's possible for the brackets to be bent. I don't see how to adjust the various components.
Bud
Gilmer Belt Throwing! 454headache Hotrodding Basics 17 05-25-2010 06:48 PM
V-belt idler pulley ? belt rides backside JeepsAreBuilt Engine 4 05-09-2010 09:01 AM
Throwing a belt biscuitville Engine 14 07-27-2008 08:25 AM
going retro from serpentine belt system back to v-belt can i swap out the reverse ro motorhead1945 Engine 5 06-25-2007 06:56 PM
will i keep throwing my belt? uneedmorethen10s General Rodding Tech 4 02-03-2004 09:49 PM
