Belts - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2004, 12:11 PM
Jessab's Avatar
New Member
Belts
What is the difference between a one belt system and two belt system? I just swapped engines in my pickup. It is a 79 C-10. I put a 305 in it. I am trying to put new belts on it. I just don't know whether to use one or two. Can someone help me out on this...
Old 05-11-2004, 12:24 PM
DoubleVision's Avatar
how many grooves are on the crank pulley? If your running with just a alternator, water pump and a power steering pump you`ll need 2 belts, if your also running a/c you`ll need 3 belts. GM went over to the serpentine system which is one wide flat belt in the mid to late 80`s.
Old 05-11-2004, 12:28 PM
Jessab's Avatar
New Member
Belt
Thanks DoubleVision...
