Originally Posted by eloc431962
The answer to you question is yes it's normal to see the bubbles when bench bleeding, Just after you run enough fluid through the M/C and don't let it go dry at any point. Once enough fluid has passed through install it and should be good to go unless you let some air get in the system during all this. JMO
Cole
eloc, nice car, i was wondering why the front res has all the bubble action and the rear has a little. but i guess its for the back brakes because they need less as stated above..
