bench bleeding master cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2006, 01:24 PM
I converted my 60 Biscayne to power disc. There were no extra fittings to try and bench bleed it. Can I still bleed at the calipers and rear drums and get the air out?
Old 11-13-2006, 01:29 PM
I've always bench bled thru the brake line ports. For dual master cylinder, plug one port and run hose from a fitting on the other. I fill both and run hose to other side while slowly pumping till air gone and then reverse process.
Old 11-13-2006, 02:03 PM
HUH? I don't have any fittings to plug any of it off. My question was,can I still get it bled?
Old 11-13-2006, 02:06 PM
You have to have fittings for the brake lines to go into.
Old 11-13-2006, 02:21 PM
You can get a bench bleeding kit from any auto parts store for about $2.
http://www.superchevy.com/technical/.../0509sc_bench/
Old 11-13-2006, 02:27 PM
poncho62's Avatar
Wiki Edits: 5
Not to change the subject but, What did you use for rotors, calipers etc............and mounting brackets?
Old 11-13-2006, 02:40 PM
I tried to find what you are showing.Auto Zone and Parts America didn't know/have. I'll try a couple others. Thanks for the reply.But my question still is:Can it still be bled without bench bleeding?
Old 11-13-2006, 02:46 PM
Well,uh,I took the easy way out,forgive me. Ordered a kit that had everything in it, including steel brake lines. What a fun filled weekend! Brake fluid and brake dust, when combined make for such an easy to remove goo!
Old 11-13-2006, 02:54 PM
It's been the recommended method for as long as there have been mc. Must be a reason. It's easy. What I do is after bench bleeding put on car, push pedal and crack the lines to bleed at the fitting, assuming your replacing mc on car with fluid in system
Old 11-13-2006, 03:07 PM
It can be bled in the car, but it's a lot easier on the bench. In the car the m/c can be hard to get level so you can bleed it effectively, and it takes a lot longer. You could probably remove it from the car, bench bleed it and re-install it in less time than it takes to do the whole job in the car. Did you read the linked article?
Old 11-13-2006, 03:30 PM
Has new lines. Left the bleeders open until they started dripping. I have brakes,but not to my liking. I may take the master off and bench bleed it.Thanks.
Old 11-13-2006, 05:32 PM
Look in the HELP section of your local auto parts store. This is the section where you find odd parts to help you get your car back together. I found a bleeder kit at Kragen's HELP section.
Old 11-13-2006, 05:55 PM
Got one tonite,4th place I've been. Gonna take it back off tomorrow.Let it bleed!
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
39 Deluxe master cylinder adapter? MM in NM Suspension - Brakes - Steering 4 09-30-2005 03:42 PM
Confusing master cylinder ports... Externet Suspension - Brakes - Steering 2 12-08-2003 08:18 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 03:38 PM
