Bench Drill Press - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 06:04 PM
Theresa Shank's Avatar
Bench Drill Press
David was wanting a bench mounted drill press for his birthday. He said he saw one some time back at the local Harbour Freight shop in Indianapolis. Have any of you guys tried this drill press? Or this supplier for such items? I alway thought Sears was the place to go ? ? THANKS.. THERESA
Old 02-06-2006, 06:30 PM
BadS10's Avatar
tools
i have found that the power tools at harbour freight are not very durable and you get what you pay for.i would suggest weighing your options were to go first
Old 02-06-2006, 07:15 PM
I have owned one of the Harbor freight drill presses for about 10-15 years , no problem so far, I have used quite a few harbor freight tools , they are somewhat cheaper but I have found they are fairly dependable (now if you got tons of cash , sears , snap-on etc.)
Old 02-06-2006, 08:24 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
One big thing to remember too is that tool life will vary with usage. I swear by my DeWalt drill and my Makita grinder, but there's no way that they'd either stand up to a full-bore 10 year run of 60 hour+ work weeks. Also, IMO, if you (or David ) take good care of the drill press and don't keep it overloaded repeatedly, even a reasonably cheap drill press will last for a good many years. In that same sense, any tool is similar to your car. If you don't change the oil, and do the routine tune-ups, it just won't last.
In a while, Chet.
Old 02-06-2006, 10:47 PM
I too have one one of those HF drill presses in my home garage(picked it up almost new at a yard sale for 15 bucks ) had it for 9 years and I have used it a bunch with no problems at all but if someone is planing to drill a lot of metal instead of wood I think the Craftsman, DeWalt etc. may be a better way to go. The thing is a bit underpowered and the table tends to tilt under pressure no matter how tight but for woodworking I think it will work just fine.
Old 02-07-2006, 02:00 AM
The Harbor Freight drill press will probably hold up just fine.
It is sad that almost everything Harbor Freight sells is made in China.
It sure would be nice to find a similar drill press that is made in America.
Old 02-07-2006, 05:55 AM
Hey Guys: Thanks for your input... THERESA
Old 02-07-2006, 02:38 PM
USA1's Avatar
This is close to you. They are pretty good about warranty, I think. http://www.mytscstore.com/detail.asp...productID=2025
Old 02-08-2006, 01:19 PM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
Problem with that is it's a CLARKE and made in Italy. What do you do for replacement parts down the road? If it lats that long?
Old 02-08-2006, 03:10 PM
Just because it's made in Italy doesn't mean it is any less durable IMHO. Several better catalogs sell Clarke equipment which I cannot imagine them doing if the quality generated a large amount of customer complaints. Plus Clarke runs an office out of Ohio and lists all the diagrams for their tools on their website along with the phone numbers to call for spare parts.
As for the Harbor Freight Drill Press, I've owned one for around 15 years and have had no issues. Their welders on the other hand are a different issue as are their small power tools.
It really all depends what it's going to be used for. If it's for some light hobbyist work then in all likelihood there's no need to rush out and buy a top of the line Delta or similar.
Old 02-08-2006, 03:11 PM
King of my Man-cave.
I bought one of those from the local Big Lots store for 50 bucks a couple of years ago. It's not worth a cent more, but it's already paid for itself with the few odd jobs I've used it for.
tom
Old 02-08-2006, 03:31 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I bought one from Home depot, its a Ryobi brand it has I think 5 different speeds (changed with a belt on different pulleys, takes a matter of 5 seconds to Chang speeds) this thing has worked great for me on metal and wood. cost is still at $99.00 at Home Depot.
Steve
Old 02-08-2006, 03:51 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
I have a HF drill press and it works fine. I don't know how long the motor would last if it was used very much.
Ryobi makes good lower end tools, especially the cordless stuff.
Old 02-11-2006, 05:48 PM
roger1's Avatar
I have bought Craftsman and Dewalt in the past and those didn't last all that long. So I started trying a few power tools from HF.
I figured that if they don't last long, at least I didn't pay that much.
So far, they seem fine.
Old 02-11-2006, 05:54 PM
poncho62's Avatar
Wiki Edits: 5
I find with the cheaper brands of tools, like drill presses, table saw etc, that they are not as accurate.....You really have to check things carefully to keep things square. They generally have lower power motors etc.
stupid question about drill bits bigfred1958 Garage - Tools 19 10-22-2007 11:53 AM
Drill press on sale.... should I buy? speede5 Garage - Tools 4 06-28-2005 04:15 PM
Drill Press runout?? daimon1054 Garage - Tools 2 04-20-2005 05:12 PM
High strength drill bit willys36@aol.com General Rodding Tech 46 01-27-2005 07:51 AM
Alright. One more quick comp lesson 4 me HemmiGremmie Hotrodders' Lounge 13 01-02-2003 07:14 PM
